Density basic question
Old   May 19, 2006, 05:24
Default Density basic question
laure
Dear all. To simplify, here is the question raise: I have a volume of water inclosed in a fixed volume of steel. There is only water in this volume. Therefore, how will Starcd take into account the buoyancy of the water? If I put the buoyancy on, then when warmed up, the water will expand, but mathematically speaking, this expansion is not possible as the volume is fixed by the steel-walls. Does StarCd integrate some elasticity for the walls? I am afraid not...so shouldn't the results be wrong? Laure
Old   May 22, 2006, 17:28
Default Re: Density basic question
Perl script
What is the expansion coefficient of water?
Old   May 29, 2006, 15:32
moritz
It will not expand, instead you will have a high pressure raise.
Precise your problem.
Old   May 31, 2006, 12:08
laure
My expansion coefficient is 0.0003914 (Beta). My problem is that with starCD, I can't model the interface between air and water, so I had to enclose the water in steel to model my problem. However, that leads to the physical probelem I explained earlier. So the pressure of the water will rise like crasy wich would not be the case in real life, as the steel would deform sufficiently to compensate that.(I have a thin steel layer).
Old   June 1, 2006, 04:43
moritz
You can model interfaces between water and air, with free surfaces (tutorial 15, StarCD 3.24), but only with constant density, and this is not your case. The pressure in your steel box is strongly dependent from the ratio between water and air. Sorry it seems, your current model is far away from the reality. StarCD can not stress analysis.
Basic Question Abhi FLUENT 1 August 4, 2007 08:07
New to CFD with some basic question Newbie Main CFD Forum 3 October 23, 2006 12:22
Basic LES question toyCFD Main CFD Forum 3 August 23, 2006 15:09
LES..Basic Question NIK Main CFD Forum 13 May 19, 2004 19:03
[basic question] beginner Main CFD Forum 4 March 14, 2002 04:15
