variable mesh size
Old   May 30, 2006, 00:28
Default variable mesh size
prathima
I want to know how to create 3D grids with variable cell size using prostar. That is when i create blocks around a model for external aerodynamic study, i want smaller cell size near the wall of the model and the cell size should increase as it moves away. How do i implement this in Prostar.
Regards, Prathima
Old   May 30, 2006, 11:47
Default Re: variable mesh size
Tom
I assume that you have a solid model of the fuid. After you prepare the surface and generate the subsurface, go to create custom mesh. There you can set the cell size you want on the surface and the smallest cell size you want at geometry changes. This will generate a large block mesh. Then go to the generate mesh panel and use your custom mesh as the starting point. See Section 6 of the proam manual. Tom
Old   May 30, 2006, 11:58
student
I would suggest use pro-surf and then pro-am same as Tom said. They will provide you better mesh then ever.
Old   May 31, 2006, 05:46
Anton Lyaskin
If you're building a block mesh in ProSTAR, you can set the "space factor" for the edges of the block which go from the wall to the exterior
Mesh size for DNS and LES Glenn Horrocks Main CFD Forum 45 May 25, 2020 15:43
[mesh manipulation] Making a mesh with different regions mesh size mou_mi OpenFOAM Meshing & Mesh Conversion 7 June 17, 2008 17:26
finite difference formulae for variable grid size yfyap Main CFD Forum 3 March 14, 2006 12:01
Mesh size suailek FLUENT 2 July 26, 2004 17:37
*VARIABLE CELL SIZE IN LES p.cooper Main CFD Forum 1 July 28, 2002 02:27
