Solid cells on symplane boundaries
Old   May 27, 2006, 10:39
Default Solid cells on symplane boundaries
samu
Hello experts,
I want to run an axi-summetric problem, so i use symmetry boundaries.
On the symmetry boundaries there are fluid, but also solid cells. The latter causes the following problem when i try to write the geom file :
NO CELL FOUND FOR BOUNDARY
The missing cells are the solid cells of the symplane boundary.
Does anybody know what's the problem and propose any solution?
Thanks in advance, samu
Old   May 27, 2006, 17:08
Default Re: Solid cells on symplane boundaries
TG
Are you sure that you have turned on conjugate heat transfer? If it is not on, then pro-STAR ignores solid cells which would probably trigger that message (it sees a boundary but it doesn't see any connected cell).
Old   May 28, 2006, 07:36
samu
Thanks for your answer, by turning Conjugate Heat Transfer on, the problem has been solved.
However, i want to simulate an isothermal problem.
Is enough to just set the same temperature in Initialization (let's say T=573K) of Material 1 (Fluid) and Material 2(Solid), or i have to make more changes as well?
samu
Old   May 29, 2006, 05:01
Ralphie
Why do you want to include solid cells in an isothermal simulation? What do you expect Star-CD to calculate?
Old   May 29, 2006, 05:24
samu
I just want to use solid cells as an adiabatic and impermeable wall, instead of baffles.
Know the next logical question is : "Why you dont use baffles instead?"
Thats because i want the wall to have thickness.
samu
Old   May 29, 2006, 05:32
Ralphie
You don't even have to use baffles...
You can just define the appropriate boundary conditions on your walls (there won't be an option to make them adiabatic if you are running an isothermal case).
Do want the thickness of your walls just for post-processing/displaying your results?
Old   May 29, 2006, 08:37
samu
I am simulating a foam catalytic converter, that contains a metalic tube fulled with holes, on which is the catalytic foam supported.
So to make a more realistic simulation (and to take more reliable results about pressure drop and velocities) i considered as a better option to use solid cells for the tube, instead of the baffles i was using until now.
However, i don't have to perform thermal calculations.
If you could propose me a better approach for the simulation of the metalic tube, you 'll be welcome.
Thanks for your interest
samu
Old   May 29, 2006, 10:07
Ralphie
The point is that if you perform isothermal calculations, the code will ignore solid cells because they do not have any influence on your fluid flow. All you have to define is the wall boundary condition.
[OpenFOAM] Displaying solid boundaries shuo ParaView 1 September 25, 2006 06:25
Mesh to points cells faces and boundaries files billy OpenFOAM Pre-Processing 19 April 18, 2006 15:38
change in solid wall boundaries with gravity? Arjen Koop Main CFD Forum 0 October 17, 2005 11:23
Flow through solid cells Julie Polyakh Siemens 1 September 6, 2003 08:18
Building solid cells kerem pekkan Siemens 0 November 21, 2000 17:47
