May 27, 2006, 12:16 |
STAR-CD to FLUENT
Sir i am having doubt, how to import the mesh the generated using GAMBIT to PRO-AMM and vice versa. Thanks in advance
with reg Sha |
May 27, 2006, 16:50 |
Re: STAR-CD to FLUENT
Going from gambit to prostar should be easy. They both read a number of shared formats (nastran, patran, CGNS...). You won't be able to take a pro-am mesh and read it into fluent because fluent can't handle trimmed cell shapes.
May 28, 2006, 19:27 |
IF you want to import Gabmbit mesh to prostar, you can just use "gambit" command.
IF you want to import prostar mesh into Gambit you must use third mesh format like patran, nastran. As I know, Fluent can read the Trim mesh. Because fluent can read the mesh which generated by Harpoon. |
May 28, 2006, 19:30 |
No-harpoon doesn't create trimmed cells which are basically a subset of polyhedra. Harpoon only creates things that fluent (and prostar) can understand. So if you create a tet or hex mesh in prostar you can export it to fluent. If you create a pro-am trimmed mesh you cannot export that to fluent. Fluent can't do polyhedra.
FLUENT/STAR-CD | John | Siemens | 2 | April 23, 2008 11:21 |
CFX-5, FLUENT 6 or Star-CD? Which one is the best? | Harendra Nath Mondal | Main CFD Forum | 4 | September 7, 2004 10:45 |
which one? FLUENT, Star-CD or CFX? | M. Amin | CFX | 2 | February 14, 2004 00:21 |
which one? FLUENT, Star-CD or CFX? | M. Amin | FLUENT | 6 | February 9, 2004 03:45 |
