Multiple Frames- Explicit (error #099)
Old   April 12, 2006, 09:32
Default Multiple Frames- Explicit (error #099)
sham
Hello erverybody, I have a question regarding Torque converter analysis. I have taken one sector from each of 3 components (Impeller, reactor &turbine). I have applied Inlet & Pressure boundary conditions at each component ends. And coupled these boundaries by regions. I tried to solve with explicit Multiple frames. For some reason it is giving Error #099. Please read following messege what I see every time I try to give a run.
*** ERROR #099 *** TANGENTIAL AREA > .005% FOR CELL 8960 FACE 2 TANGENTIAL AREA, TOTAL AREA, PERCENTAGE: -8.518357E-10 1.206000E-05 -7.063312E-03
It would be great, if someone could help me with this matter.
thanks
sham
Old   April 18, 2006, 05:34
Default Re: Multiple Frames- Explicit (error #099)
John
In explicit multiple frames, the coupling boundaries should not have area component in the tangential direrction. In your case, it seems not too bad.
You can either correct your boundary mesh a little bit to make sure there is no tangential area or simply set Real Constant 68 to 1 to ignore the area check.
Old   April 21, 2006, 08:23
sham
Thank you john it is working
Old   June 9, 2006, 00:29
bsbalachandran
hello sham!
i am just going to start the torque converter analysis using starcd. since i am a new user to star cd, could u able to help me the procedure how to proceed.
if u have any particular tutorials please reference me..
with regards bala
Old   June 9, 2006, 04:07
Ashok Barik
Two phase flow in a channel.
Multiple Rotating Reference Frames for autoclave multiphase-flow FLUENT 1 June 22, 2008 21:25
Multiple Refrance Frames Shamoon FLUENT 2 December 9, 2007 05:25
Multiple Refrance Frames Shamoon FLUENT 0 December 4, 2007 10:44
Multiple reference frames raffap Siemens 10 January 31, 2007 18:39
Multiple reference frames? Moon Siemens 0 March 4, 2003 06:32
