How accurate is cell coupling?
Old   June 22, 2006, 23:04
Default How accurate is cell coupling?
Manish
Hi, As we all know that couple cell is used in StarCD to join meshes which are not having cell to cell connectivity. Can anybody tell me what approximations are considered in StarCD while doing this. How accurate the results will be, and what are the points one should keep in mind while using the cell coupling. Thanks.
Old   June 23, 2006, 03:51
Default Re: How accurate is cell coupling?
Mac
Hi, cell coupling should be used only if inevitable. As fas as possible, make sure you have a conformal mesh for your analysis.
However if you still go ahead with a non-conformal mesh with cell coupling, then make sure that you have almost the same mesh distribution across the interface.
Old   June 23, 2006, 09:52
TG
In STAR4 there is absolutely no approximations involved in cell to cell coupling. That said, the general rules of meshing still apply. You can't couple 1 face to 1 thousand and expect anything good to come out of it.
ACCURATE MESHING AMP FLOW-3D 1 November 19, 2008 23:53
Time accurate? Steve Main CFD Forum 2 March 25, 2008 08:39
Finding a more accurate volume for each cell Rjakk Siemens 1 March 20, 2007 15:46
Time-Accurate Dave Main CFD Forum 2 March 11, 2005 15:00
Are FE computations accurate; really? philippe Fullsack Main CFD Forum 0 November 5, 2001 10:53
