Error in browse additionnal output file
Old   August 8, 2006, 05:02
Default Error in browse additionnal output file
student
Hy I am doing a free surface analysis with surface tension on I am parating in transient and when I check to my additionnal output file At each time step appear this warning: "WARNING #038*** Unormalised residual cannot be reduced to 1.0000E-10 in Eq: pcor round-off error rescue not attempted; solution returned without update" I would like to know what is the meaning of it? And how could I correct it Though this warning is my solution in my pstt file right or it isn't? thanks for you help
Old   August 8, 2006, 11:49
Default Re: Error in browse additionnal output file
Pauli
I believe the message is telling you the residual for the pressure corrector term can not be reduced to less that 1e-10. It is up to you to determine if this is good or bad. It could be good - your solution is very accurate. Or it could be bad - you have a modeling problem.
Old   August 9, 2006, 05:18
student
And how could you reduced it?
Output file as Input file Waseem Siddique Main CFD Forum 0 January 7, 2009 09:42
Writing additionnal output files during a run laurentgla OpenFOAM Running, Solving & CFD 3 May 25, 2007 10:35
Does CFX can output ".rth" file? prayskyer CFX 6 July 7, 2006 20:08
output file Astrid FLUENT 1 June 19, 2006 16:01
why can not i see the output file? macro Phoenics 1 January 2, 2004 10:25
