August 9, 2006, 08:26 |
heat source in starcd
hi friends, in my model one fluid region and four different solid regions are there. these solids having heat source 20,20,40,15 Watts respectively,volume is say a,b,c,d. how to apply these heat source to the solid regions. if you have any subroutine please mention that. thanks in advance. kiran kumar
August 9, 2006, 09:09 |
Re: heat source in starcd
sorent.f
IF(ICTID.EQ.xxx) THEN S1p = ...... S2p = ...... ENDIF easy eh |
August 15, 2006, 05:39 |
You can define it also with a table (folder Source under folder Thermalphysical Models) and you have just to defin S1P. (always in W/m3, independent from the dimension of your geometry).
September 17, 2006, 19:13 |
Funny, I was having similar problem. Sorent.f was easy but the table was not so easy. I dont understand how to key into the table and what does "independent" mean in that table? Couldn't find tutorial on this one either.
Heat source UDF, please | Sasha | Fluent UDF and Scheme Programming | 4 | October 14, 2014 01:32 |
Conj. Heat Transfer: STARCD vs. STARCCM+ | Stefano | Siemens | 0 | September 24, 2007 08:55 |
heat source | Mac | Siemens | 8 | July 15, 2007 00:50 |
Input heat source (heat/unit volume) in 2D | Polly | FLUENT | 2 | March 18, 2005 01:04 |
Heat-Source | James | Siemens | 1 | July 17, 2002 09:33 |
