how to converge the solution for fine mesh
Old   July 12, 2006, 00:44
Default how to converge the solution for fine mesh
kathiravan
hi experts i am doing one problem related to heat transfer in star cd. my prob is one heated cylinder is placed inside a square cavity. now i want to find out heat transfer coefficient around the cylinder. for coarsh mesh the solver converges very quickly. but for fine mesh it will not converges. for using SIMPLE algorithm it will diverges immeadialy. but my boundry condition everything same for coarsh and fine mesh. so how to attack this problem from very fine mesh. after that can you tell me how to plot graph for theta verses heat transfer coefficient.
Old   July 12, 2006, 04:20
Default Re: how to converge the solution for fine mesh
Zamir Rashid
Try using under relaxation factors for the solved parameters.
Old   July 12, 2006, 07:04
DenizeN
Try to read about y+ and turbulence models in user guide.
Old   July 20, 2006, 00:06
kathir
i am using only laminar flow
Old   July 20, 2006, 02:37
DenizeN
then your flow have complex structure, use transient or pseudo-transient solver. With coarse mesh you smooth flow structure and solution converged (real structure of your flow is more comlicated).
Old   August 11, 2006, 01:30
kathir
hi DenizeN
thanks for responce. in my problem i activate to print the parameter values( temp, velocity etc) of each cell. at the time the result shows the negatve temp values. how is it possible. because my air temp is 25 c and fin base temp is 100 c. but it shows surrounding air temp is less than 0. but in contour plot it not shows the negative values. but print values shows the negative values. please give me what is the mistake in my approach thank you sir
what should I do if the solution didn't converge? Beeny FLUENT 6 August 27, 2011 00:04
New geometry in tutorial mixer2d unphysical solution for fine mesh christinasmuda OpenFOAM Running, Solving & CFD 6 January 16, 2009 07:11
steady solution on fine mesh Flo Main CFD Forum 2 May 31, 2008 14:55
Solution Does Not Converge Rif Main CFD Forum 3 March 7, 2008 05:33
what to do when solution doesn't converge? Jenny CFX 5 January 28, 2004 04:00
