pressure boundary
Old   March 15, 2007, 16:07
Default pressure boundary
thomas
Hello, I am trying to run a combustion model inside a tube with two small inlets (air\fuel) and and outlet. When i was using a standard outlet boundary the code stopped due to negative velocities. Then I changed to pressure boundary. Initialy i had the pressure reference cell at the inlet, because there I know the temperature. I specified atmospheric pressure. Since I do not know the pressure drop, i changed the reference cell to one in the pressure boundary. However there I don't now the temperature.
Has anybody got any ideas?
thanks,
thomas
Old   March 20, 2007, 05:00
Default Re: pressure boundary
sidd
For models with pressure boundary, do you really need to know the pressure at the pressure reference cell?
I'm not sure, but i think you can set your pressure reference cell at the pressure boundary and run your calculation.
Old   March 21, 2007, 04:55
Anton Lyaskin
For models with pressure boundary it doesn't matter where you set your pressure reference cell. Reference temperature is not associated with pressure reference cell. However to set up pressure boundary you do need to know pressure on it! So may be in your case it's better to stay with outlet boundary but extend the domain.
Pressure boundary Paris Hdez Siemens 0 March 13, 2006 05:04
Pressure Boundary saang Siemens 2 April 28, 2005 06:57
pressure boundary VS. mass flow boundary dalton Main CFD Forum 12 April 3, 2005 23:52
boundary pressure Niru Main CFD Forum 0 June 10, 2003 02:37
Pressure Boundary Antonio Retaggio Siemens 0 September 6, 2001 12:02
