Cylindrical Coordinates in Starccm+
Old   January 22, 2007, 00:44
Default Cylindrical Coordinates in Starccm+
Josh
I set-up the model in cartesian coordinates and ran the model. Now that it is done, I realized I would like to make a contour plot of the tangential velocity. I thought I could do this by setting up a cylindrical coord. system and then selecting tangential velocity as the field function. When I tried this, the plot is blank, other velocity contours work fine. Has anyone else tried this?
Old   January 22, 2007, 16:05
Default Re: Cylindrical Coordinates in Starccm+
Chris
I think the tangential velocity is computed using the region's reference frame. You don't need to create a coordinate system.
Old   March 13, 2007, 23:25
guillaume
Hi chris the tangential velocity is defined around the z axis so you need to have a symetry around the z axis
Cylindrical coordinates amelia OpenFOAM Pre-Processing 7 September 20, 2022 01:03
cylindrical coordinates shuo Main CFD Forum 2 November 20, 2007 06:44
FVM cylindrical coordinates vm Main CFD Forum 1 January 3, 2007 09:15
cylindrical coordinates A.Schulze CFX 2 November 7, 2000 19:49
Cylindrical coordinates Nish CFX 1 May 3, 2000 03:01
