March 14, 2007, 00:41 |
CCM+ vs CFX vs Fluent
Hi I am a current user of CCM+, I am wondering what CFX and Fluent offers in terms of solver speed, meshing algorythm and user friendlyness. I use CFD in the building industry, so I am not too worried about the turbulence models used for mach > 10...
March 15, 2007, 04:09 |
Re: CCM+ vs CFX vs Fluent
My experience is on Ansys CFX v.10 in Workbench and Fluent 6.2, and I've been recently exposed to CCM+ as a CFD consultant.
My opinion is that CCM+ is the most user friendly, followed by CFX, which still retains separated mesh-pre-post-solver interfaces, and Fluent, which has the most outdated interface. Of course simulation setup speed will vary enormously depending on the user skills. About meshing, I feel the default CCM+ mesher is better than CFX Workbench mesher and somewhat less powerful than Gambit (which is the Fluent mesher). On the other side Ansys can offer what I think is the state of the art mesher: ICEM, if you can afford it. It is also to be pointed out that CCM+ has a unique polyhedra mesher, which brings me on the speed topic. On a tetrahedral cell number basis I found more speed difference between different machines than between different codes, by the way I didn't have many chanches to run benchmarks on a single machine. But if you consider that for a given problem if you use polyhedral istead of tetrahedral cells the same accuracy can generally be acheived using less than half cells, on an accuracy basis I can say CCM+ is the faster. Hope this helps, Vmax |
April 12, 2007, 16:07 |
One thing worth adding is that CFX always solves on Polyhedral control volumes, doing so by way of it's discretization rather than requiring a Polyhedral mesh up front. CFX also solves the fully coupled mass and momentum equations, making it the most robust and scalable of the three solvers.
-RK |
Fluent in Linux vs. Fluent in Windows | Melih | FLUENT | 6 | November 16, 2014 09:39 |
Fluent/Unix vs. Fluent/Windows | sjjaber | FLUENT | 10 | January 5, 2005 16:58 |
Running FLUENT 6.0 sims. on FLUENT 6.1 | ozgur | FLUENT | 2 | April 2, 2004 13:23 |
