March 22, 2007, 14:47 |
heat transfer in porous media
Is there anyone with experience in simulation of heat transfer in porous media with STAR-CD?
We are working on a project to simulate a heat exchanger with a less complex model in STAR-CD. The idea is to replace the turbulators in the oil cooler by porous media. We have so far determined the coefficients for the pressure drop by experimental data. So the pressure field as well as the velocity distribution are identical to the experiment. However, the solutions for the heat flux and temperature don't match with the experimental data. There is a higher temperature drop in the simulation then in the experiment (=> 3 to 4 times higher!!). The problem probably relies on the setting of the thermal properties of the porous region (Effective Conductivity, Turbulent Prandtl Number). How do I have to set these values? Thanks!! |
March 23, 2007, 12:43 |
Re: heat transfer in porous media
Which version of STAR-CD are you using? Heat transfer in porous media is only available in V4.02.
March 26, 2007, 15:12 |
I am using STAR-CD V3.26 and of course there is heat transfer in porous media available.
March 29, 2007, 10:40 |
We use a (solid)shadow set of cells in 3.26
April 14, 2007, 11:44 |
My post graduate student is working on heat transfer studies of a porous media(copper metal foam) for his project work under my guidance.He is using fluent for this.
April 7, 2021, 14:01 |
Pritam Sharma
Rep Power: 5 |
can you help how to define the metallic foam in ansys fluent?
and how to set up physics? I am a post graduate student working on copper metallic foam |
April 7, 2021, 14:09 |
Pritam Sharma
Rep Power: 5 |
April 7, 2021, 14:11 |
#8 | |
Pritam Sharma
Rep Power: 5 |
February 16, 2022, 07:11 |
#9 | |
Matt
You will need to enable non-thermal equilibrium, define resistance tensors, set a porosity (solid volume fraction) and define the specific heat of the solid material as well as any heat sources/sinks. The help files are actually pretty solid when it comes to documentation, assuming you find it. Sometimes the search feature provides irrelevant results. |
May 24, 2007, 05:12 |
Re: heat transfer in porous media *NM*
February 16, 2022, 07:13 |
#11 |
Matt
Sorry, I take back everything I said. Not sure how to do it in cd, was referring to ccm+. Didn’t realize anyone still used star-cd.
Heat transfer within Porous Media | Twiti | CFX | 10 | January 15, 2021 08:13 |
REG POROUS MEDIA HEAT TRANSFER | Rashmi Venkat | FLUENT | 6 | June 1, 2006 05:13 |
Porous Media with heat transfer | A.S. | Siemens | 2 | February 23, 2005 03:01 |
Heat transfer in porous media | Sri | FLUENT | 0 | January 16, 2002 22:54 |
heat transfer in porous media | Jörg Brozio | FLUENT | 1 | March 28, 2000 23:17 |
