Spray Injection
Old   March 23, 2007, 00:10
Default Spray Injection
usker
Anyone knows what is the definition of number of parcels? In Lagrangian Multi-Phase-> Spray Injection with Atomization there is Number of Parcels/Injector/s (Parcel Injection Rate). How to determine correct parcel injection rate? If I change the parcel injection rate I get completely different results.
Thanks
Old   March 23, 2007, 03:48
Default Re: Spray Injection
Richard
The number of parcels in Lagrangian is analogous to the number of cells: it doesn't have any relationship with anything physical, it's just how you choose to discretize the problem in order to make it solvable. As with cells, changing the number of parcels could change your solution, in fact it probably will. Hopefully as you increase the number of parcels (or cells) the Lagrangian (or Eulerian) solution becomes more accurate, until it becomes insensitive to further refinements - though whether you can ever afford to refine this far is another question.
Old   April 6, 2007, 00:41
usker
Richard, thank you for your previous clear explanation. Let's assume that my injector nozzle diameter is 0.0001m, I specify appropriate flow rate, number of parcels and so on, I run Star and get results. In pos-processing I select "Plot Droplets/Particle Tracks ->Droplet Plot Options->Droplet Radius->Diameter->0.0001. Then I want to plot particles distrubution with the size from 0.0001m to whatever smallest size it can show me. When I insert the size of my nozzle(0.0001m) in "Droplet Radius" as a "Diameter" i cannot see any particles on the screen, but if I increase the size to 0.1 and higher I can see particle distribution. But the problem is that how I can get right fuel liquid length. Because If I play around changing the size in "Droplet Radius" the total spray length also changes. In other words, if I increse the size of droplets, total spray length increases, and vice versa.
Please advise Thanks again
spray injection Johannes P. Siemens 8 January 14, 2009 08:38
Urgent help needed with spray injection nick Siemens 14 June 29, 2008 18:48
spray injection mmacrb FLUENT 0 January 10, 2007 04:57
water injection into air (not spray) bioman66 CFX 1 July 11, 2006 06:34
spray injection. Moon Siemens 2 May 6, 2003 01:06
