restart & pstt
Old   April 5, 2007, 02:11
Default restart & pstt
azmir
Suppose my transient case run process was interrupted, then i re-run my transient model. After that, when reading the pstt file, I only got iterations after the restart process. The iteration results from first part of the transient run was not found. Is there a way to retrieve the iteration results from frist part of my run before it was interrupted?
Old   April 5, 2007, 03:37
Default Re: restart & pstt
Richard
The files from the first run should have been moved into a RESULTS.*** directory.
Old   April 5, 2007, 03:59
azmir
Allright, this is better. How do I retrieve these earlier results say I ran them on LINUX 8 cpu. Mergepst? That command is not recognized.
Old   April 5, 2007, 08:17
Richard
The pstt file in the RESULTS.*** directory should already be merged, you don't need to merge it yourself.
No .pstt file Luke Siemens 2 July 24, 2008 09:26
restart & pstt azmir Siemens 0 April 5, 2007 03:57
unload *.pstt tipakorn Siemens 1 September 6, 2006 10:34
.pstt file Andy Siemens 6 March 28, 2006 02:07
PSTT File Yuan Shen Siemens 6 November 7, 2000 08:09
