Help needed with convergence
Old   April 13, 2007, 20:26
Default Help needed with convergence
Shashank
Iam working on a incompressible viscous flow problem, and i have been using Mars along with simple numerical solution method. My convergence tolerance is 1e-4.
My residual values come down upto 2e-3 and sit there and oscilate just a bit they neither go down nor they diverge, i have tried all the tricks playing around with convergence factors and tolerances and blending factors but my solution refuses to go below 1e-4.
I have checked the mesh a 100 times and it looks quite good, iam just not able to understand where i need to look into in order to solve this problem.
I would really appreciate any help in this regard
Old   April 14, 2007, 04:46
Default Re: Help needed with convergence
Ben
Are the boundary conditions well posed? Is the outlet too close to any features, do you have high gradients across it? Are there any undsteady features in the simulation?
Old   April 14, 2007, 18:29
Shashank
I Have used prescribed flow split BC's , I created extrusions at the inlets and outlets and they don't seem to have high gradients.
Old   April 15, 2007, 07:22
Ben
Try using pressure boundaries instead, they tend to be a little more stable, flow split can over-constrain the system
Old   April 15, 2007, 13:20
Shashank
The problem is that i have no idea about the pressures at the boundary, thats why i had to use the flow split boundary conditions, but thank you for the reply.
What else do you think might be wrong
Old   April 15, 2007, 14:50
Balduin Bankerotti
It is very likely that your flow problem is not steady state and the oscillations are normal, especially if the mesh if fine enough.
Run it transient.
Old   April 15, 2007, 15:27
Ben
Just put the pressure as 0, try it....
Old   April 17, 2007, 02:31
sidd
I think, if the residual is getting stablized ( neither converging nor diverging), then results can be post-processed.
And very much this can be the issue of geometry variation or mesh quality for capturing gradients or the boundary condition specified as Ben said. You may have to do some tests with these features.
Old   April 17, 2007, 19:30
Shashank
Thank you very much guys for all these suggestions i will work on them and let you know how it goes.
Old   April 22, 2007, 17:37
star user
try UD initially and then change to MARS. it will help u.
Old   May 2, 2007, 05:14
  #11
Scibor
Ttry to restart the run with SMPISO solution procedure (With under-relaxation for press of 0.5) and choose AMG alghoritm, remember that this solution is really heavy for your processor, but I think it's quite sure you're getting results!
URF and convergence in natural convergence Marie-Anne Main CFD Forum 11 September 11, 2009 10:07
UDF help needed~ Nelly FLUENT 2 January 17, 2007 05:03
Help needed David FLUENT 1 December 21, 2006 08:36
Help needed with UDF sam FLUENT 5 October 26, 2005 02:48
Help needed Neelanjan Main CFD Forum 1 February 29, 2000 11:40
