May 15, 2007, 04:44 |
(step) combustion reactions
hello all defining both step combustion reactions and complete combustion reaction in one step (of propane) i get a warning that left and right hand sides of reaction aren't equal; checking it by hand, using data from STAR_CD database i get values approximately equal to the RHS-values shown in the output window; have you ever faced something similar? what to do? thx in advance
May 15, 2007, 19:11 |
Re: (step) combustion reactions
Approximately equal to is not the same as exactly equal to. Prostar requires exactly equal to.
Check it again until you sort out why Prostar is doing what you ask instead of what you desire. I've had this problem. So I feel your pain. Unfortunately it's been a while & I don't remember all the gory details. Is it something with how the base fluid is book kept? This is a basic stoichiometry calculation. I'm a little confused when you say you used data from the StarCD database. What data? |
May 15, 2007, 20:52 |
Please, send the reaction formula. After I see it I can tell you what is the problem.
Regards |
May 16, 2007, 09:49 |
thx a lot; i have already solved the problem; one of the data from database was wrong; regards
Multi step reations (80 reactions mechanism) simul | Patrick | Main CFD Forum | 0 | August 16, 2008 12:17 |
time step in unsteady combustion process | FRANK LEE | FLUENT | 2 | July 25, 2007 04:51 |
premixed combustion step? | John | FLUENT | 0 | August 12, 2004 22:03 |
MIX_FRAC-FUEL_2 in 2-step combustion | Julie Polyakh | Siemens | 1 | April 28, 2004 03:16 |
