velocity normal to the surface
Old   May 8, 2007, 06:52
Default velocity normal to the surface
srinivas
hi
Can anybody plz tell me how to set the velocity normal to the surface ?
Thanks in Advance
Old   May 30, 2007, 02:03
Default Re: velocity normal to the surface
george
Dear Srinivas,
As I imagine, the velocity normal to the surface for example in x direction is velocity V. When you give values for boundary conditions go to the wall and give the appropriate value for V. If you have a profile of velocities (e.g. V is changing with heigth y) then you can define a table of values V which are dependent of height Y and go to the boundary of walls and change the standard to table (there is a tutorial how to define tables I thing is the fifth tutorial).I hope I helped you.
Regards George
How to get the surface normal vector ohrmond CFX 3 February 1, 2018 05:45
WALL normal velocity Luca Main CFD Forum 1 October 8, 2014 05:21
Normal to boundary velocity alberto OpenFOAM Pre-Processing 6 July 3, 2007 08:16
Normal - Helical Surface m. malik Main CFD Forum 3 February 3, 2006 12:56
Velocity gradient normal to a wall ap FLUENT 0 July 26, 2004 08:32
