partial boundary(between two cylinder)
Old   June 3, 2007, 01:48
Default partial boundary(between two cylinder)
Elyor
Hi guys, i created couple between two cylinders with "partial boundary on" option. After coupling some partial boundary cells become empty. how i can fix that cell, any suggestions. thanks an advance.
here are that pictures.
http://www.geocities.com/elyor_1101/...hecoupling.jpg
Regards,
Old   June 8, 2007, 04:04
Default Re: partial boundary(between two cylinder)
Mac
Hi...its a visualization problem. Check the grid for cracks to see if there is any dis-continuity. If you are able to write the prob and geom file, there should not be any problem.
Old   June 8, 2007, 07:55
Elyor
Thank you very much Mac for your answer, that is what i want to know, yes i am able to write the prob. and geom. file, also i got converge solution.
partial derivative Rita CFX 3 May 21, 2018 06:24
Wall boundary conditions for 3d-cylinder Martin Bellmann FLUENT 1 July 11, 2008 13:04
Pls Help on DPM BC Partial Evaporation xc FLUENT 4 January 18, 2006 15:53
Partial slip boundary condition? Baicang FLUENT 0 November 13, 2005 05:48
About Partial Cyclic Boundary Condition Jiaying Xu Siemens 2 October 31, 2002 20:12
