June 21, 2007, 08:10 |
REFINE IN ONE DIRECTION
i WANT TO REFINE A CELLSET IN A PARTICULAR DIRECTION.sOME CELLS ARE REFINED IN ONE DIRECTION AND OTHERS IN OTHER DIRECTION.hOW TO RESOLVE THE ISSUE. i have read some where about cdirect and creorder commands but i am not able to do.
kindly help Thanks in advance |
June 21, 2007, 11:53 |
Re: REFINE IN ONE DIRECTION
CDIRection goes with the command CDIVide.
You establish the cell I, J and K directions with CDIR Then you use CDIV to split the cells in any given direction It sounds like you were using CREF on a multi block mesh with different local directions previously. This splits cells based on the existing I,J and K direction of each cell. If for some reason you wanted to use CREF then you could do CDIVide RESTructure CREFine but that merely adds an extra step PLFACE ON with a PLTY EHID shows you the cell face orientations of the mesh I believe CREOrder is/was mainly used for reducing the wave front of linear FEA solvers by renumbering the cells such the neighbours had similar cell numbers. I am not sure that it has that many uses other than that |
June 26, 2007, 03:32 |
hi. why you don't use the way like "prostar window-->tools--> cell tool--> cell refine" ?
June 26, 2007, 05:17 |
In 326
try the "cmro" command with the option 1d or vector then use cmre cset This should handle all cell type |
refine mesh!! | Donia | FLUENT | 2 | June 2, 2007 17:13 |
refine | harry | FLUENT | 0 | February 28, 2007 13:35 |
refine issue | judy | Siemens | 6 | January 4, 2004 02:36 |
REFINE | Sunlight007 | Siemens | 2 | December 6, 2003 15:40 |
Refine | Stefano | CFX | 1 | February 25, 2003 09:45 |
