parallel computing
Old   June 25, 2007, 06:18
Default parallel computing
rui
Hi everyone,
I got a problem with parallel computation. I wanna use table for the inlet boundary condition, also am using the posdat.f subroutine. However, when I run the case in the cluster, star-cd told me some error information as follow. Anyone has any clueS????
Any message will be highly appreiciated!
error messages:
*** Reading geometry *** /var/spool/pbs/mom_priv/jobs/582.b21g.be.SC: line 25: 15614 Killed star -dp -copy="inlet.tbl" $PNP_JOBNODES
*** JOB STAGE 1 COMPLETED ***
----------------------------------------------------------------------------- One of the processes started by mpirun has exited with a nonzero exit code. This typically indicates that the process finished in error. If your process did not finish in error, be sure to include a "return 0" or "exit(0)" in your C code before exiting the application.
PID 16075 failed on node n0 (192.168.0.10) due to signal 9. -----------------------------------------------------------------------------
parallel computing James Main CFD Forum 11 April 14, 2009 04:21
parallel computing Daniel FLUENT 1 November 21, 2007 16:09
Parallel Computing Himanshu Almadi FLUENT 0 April 12, 2006 12:43
Parallel computing Himanshu FLUENT 0 January 23, 2006 10:21
Parallel computing jak Main CFD Forum 7 August 17, 2004 12:26
