REFINE IN ONE DIRECTION
Old   June 21, 2007, 08:10
Default REFINE IN ONE DIRECTION
star
i WANT TO REFINE A CELLSET IN A PARTICULAR DIRECTION.sOME CELLS ARE REFINED IN ONE DIRECTION AND OTHERS IN OTHER DIRECTION.hOW TO RESOLVE THE ISSUE. i have read some where about cdirect and creorder commands but i am not able to do.
kindly help
Thanks in advance
Old   June 21, 2007, 11:53
Default Re: REFINE IN ONE DIRECTION
James
CDIRection goes with the command CDIVide.
You establish the cell I, J and K directions with CDIR
Then you use CDIV to split the cells in any given direction
It sounds like you were using CREF on a multi block mesh with different local directions previously. This splits cells based on the existing I,J and K direction of each cell.
If for some reason you wanted to use CREF then you could do
CDIVide RESTructure CREFine
but that merely adds an extra step
PLFACE ON with a PLTY EHID shows you the cell face orientations of the mesh
I believe CREOrder is/was mainly used for reducing the wave front of linear FEA solvers by renumbering the cells such the neighbours had similar cell numbers. I am not sure that it has that many uses other than that
Old   June 26, 2007, 03:32
murash-v
hi. why you don't use the way like "prostar window-->tools--> cell tool--> cell refine" ?
Old   June 26, 2007, 05:17
groundhog
In 326
try the "cmro" command
with the option 1d or vector
then use cmre cset
This should handle all cell type
refine mesh!! Donia FLUENT 2 June 2, 2007 17:13
refine harry FLUENT 0 February 28, 2007 13:35
refine issue judy Siemens 6 January 4, 2004 02:36
REFINE Sunlight007 Siemens 2 December 6, 2003 15:40
Refine Stefano CFX 1 February 25, 2003 09:45
