Relaxation and Solver Parameters
Old   July 9, 2007, 06:11
Default Relaxation and Solver Parameters
norbinou
I want to now if the the number of sweeps and Residual tolerance a causes for divergance (work with Star-CD 3.26)
thanks,
Old   August 6, 2007, 05:34
Default Re: Relaxation and Solver Parameters
pankaj saha
plz, can u tell, when we are using modified MAC method and solving 3d-channel turbulent flow. 1. should we use underrelax or overrelax. 2. what should be the continuity satisfying limit. 3. what shoul be the inlet velocity profile and initial condition for tha channel for turbulent flow simulation.
this is rectangular channel.
Old   August 21, 2007, 17:46
pankaj saha
hi,
actually i am not using any software...i wrote a code in fortran using SMAC solver./
so, can u plz help me to ans my question in pretext to code not in softre...
Old   September 25, 2007, 01:38
norbinou
I use underrelax 1E-04, think you should underrelax. If you have a rectangular profile, i think you should use rectangular profile @ initial velocity.
So I think you need to do that, an after you can see, if the result is correct or no, you can calculate maybe the pressure drop, an look in significant or not.
exper parameters on solver laura CFX 1 January 9, 2009 07:50
parameters to select a solver for a model in gambt abid FLUENT 2 September 20, 2006 13:07
How to set the two parameters of solver binterFoamb luckyluke OpenFOAM Running, Solving & CFD 7 June 3, 2005 06:33
Relaxation Parameters. J. Keays Main CFD Forum 3 October 16, 2000 13:42
Relaxation Parameters. J. Keays FLUENT 1 October 16, 2000 02:00
