Temperature drops in Methane combustion
Old   July 24, 2007, 12:56
Default Temperature drops in Methane combustion
CPRL
Hi. I am trying to simulate methane combustion with air using Unpremixed/Diffusion and Chemical Kinetics scheme. There are separate air and methane inlets to the chamber and the flow is laminar. This is a single step global reaction. The ignition cells are set to 4000 K. In the beginning, when the ignition starts (from 400 to 500 iteration), I see high temperature rise and the combustion products (H2O and CO2) around the ignition cells. However, as the iteration number increases the temperature drops and reaches the normal room temperature and CO2 and H2O disappear. Anyone has idea why is it happening? Thanks for the help.
high temperature in methane combustion David FLUENT 3 August 2, 2010 02:37
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
high temperature in methane combustion Özer AYDIN FLUENT 9 April 24, 2005 16:11
Methane+air temperature too high Stanislav Kraev FLUENT 5 June 3, 2004 10:54
Methane Combustion Lars FLUENT 4 March 5, 2003 08:24
