Using DGSUM in POSDAT.
Old   September 11, 2007, 08:02
Default Using DGSUM in POSDAT.
Correia
Does someone has an example on how to use the function DGSUM in a parallel run?
I'm try to compute the average temperature from several fluid regions defined among a channel. Each region is build with up to 10 cells. I save the IP number (Pro-STAR cell number) and region number saved in two arrays in a common block in the form: myRegion IP 100 1034 100 1054 100 1029 200 3020 200 3063 ... In POSDAT I create a DO loop to read the cell temperature "T(IP)" and volume "VOL(IP)". For each sensor the Temperature average will be computed. In a single Processor It works very fine. But with two processors the results doesn't make sense. To understand I create an array to save the total volume on each sensor and for a parallel run I add in my code the DGSUM function.
DO i=1,NoOfRegions IF(NHPC.GT.1)THEN ! for parallel run
TotalVol(i)=DGSUM(TotalVol(i)) ENDIF ENDDO
But the results from the last regions (computed in the second Host) are added to the first regions(computed in the first Host). I guess problem by the cell number. But I realy don't know. I can send the Model with user functions if someone want to take a look.
Thank you in advance.
error in posdat.f tipakorn Siemens 4 August 24, 2007 07:42
CFL in posdat hamodi Siemens 2 August 6, 2007 02:27
POSDAT Sheila Siemens 2 February 8, 2006 11:08
posdat in HPC Won-Geun Lee Siemens 0 May 23, 2001 20:03
Posdat Maria Carlsson Siemens 1 April 30, 2001 10:29
