October 9, 2007, 06:22 |
setting limits
Hi....is there any way of setting limits in STARCD (be it velocity, pressure, turbulence, etc), as in solution limits?? In this way you are imposing the limits on the computation, and should the computed values increase beyond this...the iteration is terminated by the solver. Can these limits be set in the solver?? Thanks in advance.
October 9, 2007, 08:00 |
Re: setting limits
Yes, it is possible to do with real constants, at least from the lower side (you should contact CD-Adapco to find out which one for what). But iterations will not be terminated by the solver, it will just set the variable to the limiter value
October 9, 2007, 08:07 |
Re: setting limits
Thanks for the reply. How do I set the limiter value in the real constant? Can you help me with this. Thanks.
October 10, 2007, 05:51 |
Re: setting limits
Just use RCONST <constant number> <value> or go to Analysis Controls->Other Controls->Switches and Real Constants panel, then choose Real Constants tab
October 10, 2007, 06:37 |
Re: setting limits
I wanted to know the real constant number that should be activated for setting the limits. Do you have the real constant value ?? Thanks - Mac.
October 11, 2007, 07:13 |
Re: setting limits
For real constant numbers you should ask CD-Adpaco. As far as I remember, something was also mentioned at this foru.
Display Modes | |
solution limits | seeyou | FLUENT | 0 | July 21, 2007 23:27 |
Setting Solution Limits | S K Prasad | Main CFD Forum | 0 | January 3, 2006 04:45 |
Setting Solution Limits | S K Prasad | FLUENT | 0 | January 3, 2006 03:18 |
Solution limits | pp | FLUENT | 1 | June 28, 2004 12:53 |
Limits on the number of BC | Tim P. | FLUENT | 0 | June 14, 2004 15:15 |
