debugger with STAR CD V4
Old   November 27, 2007, 21:46
Default debugger with STAR CD V4
Jaishree
Hi
Can anyone help me out in how to use the debugger while running the case having the user subroutines. Basically, I want to implement check bounds etc. Is there also any info regarding how to set the flags of 'no optimization', flush denormalize,'floating point exceptions' etc. while running the star with subroutines.
Thanks
Old   December 2, 2007, 14:40
Default Re: debugger with STAR CD V4
subroutine
The best way is to add print statements. If you need a debugger it means you are writing a long code. In this situation, write and debug the code you are writing on the side, there after plug it to star-cd via a call statement within one of the subroutine. This is the correct practice.
Foam 13 How can one run solver in debugger atzaru OpenFOAM 7 July 6, 2009 11:45
Using the T array in posdat.f, sigsegv, debugger Daniel Siemens 2 February 22, 2008 12:54
fortran debugger John Deas Main CFD Forum 10 April 4, 2007 03:30
Intel Fortran debugger with mpirun agg Main CFD Forum 2 March 21, 2007 17:43
Visual Fortran compiler and debugger on linux CFD Student Main CFD Forum 3 February 26, 2007 06:26
