Coupled vs Seg - Natural vs. Forced Convection
Old   July 16, 2007, 08:24
Default Coupled vs Seg - Natural vs. Forced Convection
Alex
I am running a simulation to determine the effect of forced convection flow over a hot component.
Initially I am running a sim to match experimental results for the case temperature against CFD CHT results, using coupled solver. Then I intend to apply a forced velocity of air over the part to determine the reduction in case temperature due to this forced convection.
Two questions:
1- Why is there such a large difference in the case temperature for coupled vs. segregated solvers in natural convection (buoyancy-driven flow)?
2- Which solver should I use to compare forced vs. natural convection? For individual models I would use coupled for natural and segregated for forced and assume incompressible flow but I want to keep all parameters the same apart from the air velocity.
Would you recommend sticking to coupled for both and applying the ideal gas law for forced convection?
Thanks.
Old   July 17, 2007, 04:53
Default Re: Coupled vs Seg - Natural vs. Forced Convection
PETE
which star version do you use? Do you really have a large difference for coupled and segregated in case of natural conv.?
Old   July 17, 2007, 05:19
Alex
STAR-CCM+ 2.08. I adjusted the setup and have managed to get the coupled solver to agree closely with test results for the buoyancy driven flow. Initially the coupled solver was suggesting a few degrees temp increase when segregated was suggesting over 30deg.
Is the coupled solver likely to give good results for forced convection flow?
Old   October 5, 2007, 00:18
chin
what is the difference between natural and forced convenction? plz post me reply to my mail
Old   October 5, 2007, 06:37
Alex
Natural = Bouyancy driven due to changes in air density with temperature. Forced = Fan driven.
Old   December 12, 2007, 04:58
sivaraj.c
forced convection Kangre FLUENT 0 October 15, 2007 11:41
help please with forced convection lucia FLUENT 3 September 7, 2007 16:59
forced convection eros CFX 0 October 16, 2006 04:47
natural and forced convection Jan Main CFD Forum 4 November 30, 2005 22:44
giving natural and forced convection bc's Venu Gopal FLUENT 0 August 29, 2004 10:59
