pro-am meshing
Old   February 26, 2008, 06:00
Default pro-am meshing
Mac
Hi, would like to know if there are any options in pro-am for meshing both internal and external fluid domains at the same time?? Also, how can i switch meshing between internal and external domains?? Thanks in advance.
Old   February 26, 2008, 07:24
Default Re: pro-am meshing
BastiL
As far as I know there is no such option. Switching is done by orientation of the boundary shells.
Regards.
Old   February 26, 2008, 22:42
Mac
Thanks...but can you tell me how to orient the boundary shells ?? what did you actually mean by this?? Regards.
Old   February 27, 2008, 04:14
Anton Lyaskin
Do you have a bounding box for external domain? If not - make it first. Then under "Prepare surfaces" you'll be able to run an orientation check and fix the orientation - ProAM will automatically recognise that you'll have a doubly-connected region.
Old   February 28, 2008, 22:33
Kris
cori cset to orient shells To switch between internal and external meshing, use the Flipped Shell Orientation check box in advanced options of pro-am
Old   February 29, 2008, 03:11
Mac
Thanks....however had another question. Initially, how will i know whether Pro-Am will mesh the internal or external domain?? Regards.
Old   February 29, 2008, 11:39
Kris
after "cori cset", look at the plot with "plfa on"...I think by default pro-am is meshing the red side with positive shell normal
Old   February 29, 2008, 13:11
allan
Er...
It is much easier to do this type of meshing in ccm+. I'm not sure, but I don't think you can use polyhedra cells for this type of meshing in proam, only tets with prism layers. Trust me use ccm+ if you can!
regards
allan
Old   March 1, 2008, 06:22
Reza
Mac,
I Recomend you to select which mesh are you going to create first (e.g. internal mesh). Then select all surfaces bounding your internal volume by puting all of them in CSET. Then make a CSET INVERT then CDEL CSET. Mesh your volume with Pro-Am then using export grid in star-cd .cel and .vrt
Then do a resume model and then do the exact same thing only this time its for the external mesh. After you finish creating the external mesh, make an import grid of your internal mesh. finally do a Vertex merge.
If you do have any baffle or interfaces connecting both sides you are likely to get unmatched vertices due to resurfacing step in Pro-Am, you might just have to couple both unmatched two volumes.
I hope this trick will help..
Reza
Hexa meshing or Tetra meshing??? NITIN DEWANGAN CFX 5 August 5, 2008 09:59
need of meshing usha FLUENT 3 September 7, 2005 10:05
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
meshing in CFX 5.5 henry CFX 4 January 26, 2002 01:08
