how to put post-processing values in a text file
Old   March 25, 2008, 11:22
Default how to put post-processing values in a text file
herve
Hello, I ran my simulation and get some results. I managed to plot some graphs (pressure along a spline) on the screen, and I need to put those values in a text file to study them (on Excel). If I put my graphs in a .plot file, and read the file (like any text file, on Windows, not with StarCD), the values in it doesn't seem to be the values which are in my registers. Could someone help me on that problem? Thanks in advance.
PS: More precisely, I'd like to calculate the pressure integral on a particular section, which I don't think it's possible directly on StarCD. (actually, I need to calculate the lift and drag coefficients of my system).
Old   March 25, 2008, 14:17
Default Re: how to put post-processing values in a text fi
BastiL
You can wrie them of a graph register. It is possible to write the graph registers into a file (see help or GUI, I do not remember exact command) Plot-File is some kind of CD-adapco own format for pictures. If you need all results get them from post-registers. You can also integrate pressure there....
Taking results to Excel is not that kind of an good idea. Excel is limited to something below 64k lines....
Regards
Old   March 26, 2008, 08:42
Anton Lyaskin
The command is SDATA
Old   March 31, 2008, 10:07
herve
thanks a lot! it works!
creating .tbl file from post-processing data? Tobi Siemens 2 August 10, 2008 09:30
reading values from a text file into a java macro Jayson Martinez Siemens 1 May 23, 2008 17:58
Extracting Post Data to a Text File Ram CFX 3 March 3, 2006 06:20
post processing CL values Joe Bryant FLUENT 2 October 18, 2004 04:17
5.5.1 Post text bogesz CFX 0 June 2, 2003 09:38
