volume source problems in ccm v3
Old   April 8, 2008, 15:51
Default volume source problems in ccm v3
tom
Hi all,
I add a volume source in a region in star-ccm+ v3, then I generate the mesh. After this, I see that the mesh generated inside the volume source has a strange pattern to it, and it is also of very poor quality around region boundaries. This doesn't seem to be evident in earlier versions. Has anyone experienced this? Is there some way to recitfy this, or do I need to go back to earlier versions.
Tom
Old   April 9, 2008, 01:09
Default Re: volume source problems in ccm v3
Andrew
Which mesh models are you implementing?
Old   April 9, 2008, 03:12
tom
This happens with both tetrahedral and poly mesh.
I use polyhedral/tetrahedral, prism layer, surface remesher models. Due you think that the cause is a certain combination of models? This effect happens also in v2.10 but not earlier versions than that, so I don't think it is due to the introduction of the extruder model.
Thanks
Old   April 9, 2008, 09:22
Jim
I don't see how it can be anything to do with the extruder unless you are turning it on and using it. The volume sources did change in 2.10 so that you get a more even distribution of cells (I think I read that in the release notes you might want to check it out) what is the face validity of the cells and do they make the run diverge?
Old   April 10, 2008, 11:52
tom
Hi Jim,
Then I guess the guys at Adapco have a strange definition of uniformity. To me, if they were to properly enhance the uniformity of mesh then all adjacent cells, within the volume source, should be of the same size with the only exceptions being the boundary cells. Instead, now, for every 4 adjacent of equal size there is a small one squeezed in at the corners. This cell is over 2 times smaller, and thats why I get an odd pattern.
Is this a more prefered way of meshing, otherwise I don't understand why they have changed this.
I prefer the older way, at least I have more control over the "general" cell size within the volume source.
Thanks, Tom
Problems while compiling source sahas OpenFOAM Installation 2 October 20, 2007 12:47
Problems with negative volume cells Shashank Siemens 2 April 4, 2007 18:24
momentum source: continuity problems Johannes Radke CFX 2 December 17, 2004 04:21
source term problems!!! Christian FLUENT 0 June 10, 2003 10:33
Problems with Volume Fraction Richard Pemberton CFX 1 May 27, 2001 10:49
