transient calculations!
Old   April 10, 2008, 12:16
Default transient calculations!
lelia
hy, what can be changed or improved in mesh generation or boundaries conditions in order to increase the time step for the transient calculations? the biggest time step for which the calculations are not divergent after few iterations is 0.001s... thanx! lelia
Old   April 10, 2008, 22:42
Default Re: transient calculations!
Sachin
Can you please try to decrease the mesh size and see whether it works or else you have to check the boundary conditions again.. that is the best if you have to increase the time step.
Sachin
Old   April 11, 2008, 04:52
lelia
hy! thankx for the advice...but can u be more explicit...by decreasing the mesh size u mean the number of cells or the cells dimensions? because i have around 200.000 cells but the smallest one has 0.0006m. then, for the boundaries conditions, i have an inlet and an outlet...i'am confused a bit...i appreciate if u give a more detalied explanation. thankx! regards,lelia
Old   April 11, 2008, 11:15
Sachin Patil
You have to decrease the mesh size. Refine your mesh. But this will cause increase in number of cells which will take more PC run time. Regarding boundary conditions, do check them again by plotting each and every boundary conditions. Even if you miss small thing it will diverge. Good luck.
Sachin
Old   April 11, 2008, 12:00
lelia
thankx, just that i can't go bellow 0.0006m which is the smallest cell dimension, because i already have 270.000 cells...and for the boundaries conditions, i cant find the problem, if there any...im trying to solve the fluid flow in steady state and then just the particles ( because i have a 2 phase problem) in transient hopping that it will take less time and that the errors induced are acceptable.. regards, lelia
Old   April 11, 2008, 12:50
Sachin
It is ok if you can not reduce the mesh size for some of the cells. Try to refine the mesh whereever you can. I hope this helps.
Regards, Sachin
Old   April 11, 2008, 14:50
tom
If u are using ccm+ turn off volume sources, and hope for the best by refining your surface mesh
Old   April 11, 2008, 15:36
lelia
no, i'am working under Star-Cd 3.26...but is there any chance to simulate in the same time the fluid flow in steady state and particles motion in transient?
Old   April 13, 2008, 11:17
Anton Lyaskin
No, it should be done in two steps. If you do uncoupled simulation (i.e. particle do not affect the flow) then you can first get a steady state solution for the flow without particles, afterwards add particles, turn off flow field solution and make a restart. In this case at the second step you'll have to solve only particle motion equations.
Old   April 14, 2008, 08:33
lelia
hi Anton! you always have answers for my problems?! thankx a lot! in fact that's what i have done. first i considered just the fluid flow in steady state, then i have restarted the simulation using the steady state results and adding the particles and this time in transient state. i also turned off the solvers for fluid ( equation behavior - primary variables - u-mom,v-mom...). that's the idea, isn't it? thankx! regards, lelia
Transient Flow, Transient Pressure in Work Bench Erich CFX 1 May 8, 2007 11:55
nox calculations antonietta FLUENT 0 September 7, 2005 09:55
y+ calculations henry CFX 9 June 27, 2002 20:48
file-size in transient calculations John FLUENT 1 February 12, 2001 15:13
Implicit transient calculations using Fluent5 G. Berntsen Main CFD Forum 4 November 10, 1999 15:32
