StarDesign preprocessing error
Old   May 24, 2008, 22:56
Default StarDesign preprocessing error
Nick
Hey all, I'm currently trying to import a geometry i've made in stardesign to star-CD. I create the model, then try to run the preprocessing to generate a grid, but starccm doesn't seem to start a server properly and comes back with the following error.
Annotation: Exception occurred in Request Processor java.io.IOException: String index out of range: -1.
at star.base.neo.NeoClient.execute(NeoClient.java:230 )
at star.base.neo.NeoClient.execute(NeoClient.java:114 )
at star.base.neo.NeoClient.execute(NeoClient.java:103 )
at star.base.neo.NeoClient.execute(NeoClient.java:95)
at star.base.neo.NeoClient.connect(NeoClient.java:47)
at star.base.neo.ServerConnection.connect(ServerConne ction.java:98)
at star.base.neo.ServerConnection.<init>(ServerConnec tion.java:62)
at star.coremodule.SimulationProcessObject.<init>(Sim ulationProcessObject.java:150)
at star.coremodule.ui.SessionNode.connect(SessionNode .java:106)
at star.coremodule.actions.SessionConnectAction$1.run (SessionConnectAction.java:76)
at org.openide.util.Task.run(Task.java:136)
at org.openide.util.RequestProcessor$Task.run(Request Processor.java:330)
at org.openide.util.RequestProcessor$Processor.run(Re questProcessor.java:686) Caused by: java.io.IOException: String index out of range: -1
at org.apache.xmlrpc.XmlRpcClientLite$LiteWorker.exec ute(Unknown Source)
at org.apache.xmlrpc.XmlRpcClient.execute(Unknown Source)
at star.base.neo.NeoClient.execute(NeoClient.java:225 ) [catch] ... 12 more
just wondering if any of you would be able to help me out in the matter as its pretty urgent.
cheers.
Nick
Seg fault when preprocessing prism bmeagle OpenFOAM Pre-Processing 0 July 20, 2006 17:01
error during generate mesh in stardesign xhliu1 Siemens 1 July 29, 2005 08:59
Preprocessing RAJURAMAIAH CFX 2 November 16, 2004 16:17
Gambit preprocessing for periodic geometry Karl Kevala FLUENT 7 February 12, 2001 06:44
Preprocessing Software Brian Bakowski Main CFD Forum 1 October 14, 2000 15:33
