on the definition of Start in shell autoignition
Old   June 18, 2008, 10:33
Default on the definition of Start in shell autoignition
mepgzzi
Hi all,
I found this in starcd users guide:
Start, End " Ignition starting and finishing time or time step no., depending on the When? menu setting. Use a realistic value, e.g. the start of ignition, for the Start time but set the Finish time to a large number, so that ignition cut-off may be controlled solely by the limiting values specified above.
I can quite understand the realistic value of start of ingnition for spark ignition. But how do we define the ignition start of a compression ignition case then?
Mepgzzi
Hydrogen autoignition George Main CFD Forum 2 January 14, 2010 03:06
CCM+ & ssh shell on IBM Petr Siemens 0 December 5, 2008 03:29
FSI- shell Federica Main CFD Forum 0 February 28, 2007 18:50
Shell Aline Siemens 6 July 7, 2004 02:30
Shell Autoignition Model Shahrokh Hajireza Siemens 0 September 5, 2001 12:17
