looping a macro
Old   July 3, 2008, 18:17
Default looping a macro
Troy
I'm trying to edit a macro so that it is included in a for loop. When I add the "for" command and try running it, I get errors that seem like it's not recognizing the command.
Do I need more commands than the "for" statement below?
I'm not fluent in Java, so forgive the naivety
************************************************** ****** (from an archived thread)
it is pretty easy to do
firstly setup your model then record a macro that contains
1) the pressing of the step button. This makes the simulation take one timestep/iteration
2) the post processing steps you want (exports etc)
Stop the recording and open up the java file. The next step is to wrap this code in a java for or while statement, for example
int imax=100; //maximum number of steps
for(i=0;i<imax;i++){
// insert your recorded macro code here
Any java book or a bit of work with google should sort you out.
looping rr123 FLUENT 1 July 8, 2008 17:49
load sheme macro (Solv Execute Command macro) manu FLUENT 2 March 13, 2008 01:00
Looping in UDF!!! safa FLUENT 0 December 11, 2007 08:07
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 04:18
looping macro equivalence Swarup FLUENT 1 June 8, 2006 05:14
