Create 3d Grid query - Star cd 3.24.0 version
Old   October 7, 2008, 12:10
Default Create 3d Grid query - Star cd 3.24.0 version
Pankaj
I need to conduct transient analysis of simple toroidal geometry (3d tube) and am currently working on creating a toroidal mesh for the same.
From the tutorials, I understand that I am supposed to use the "Star CD guide - CREATE 3D GRIDS USING SIMPLE SHAPES". While conducting the same I come across an error which says that I need my cells type to be "Fluid" and not "shells", but the grid generated using "Pro-Surf" consists of "shell type cells".
Now I am unable to find a way to convert my existing Shell type cells to Fluid type cells.Is there a way to figure this out?
Also,If a mesh is created using "Pro-Am" and then the CREATE 3d GRID section is used to create an overlaying mesh, is there a way to get rid of the previous mesh which is created using "Pro-AM" and just restore the mesh created using CREATE 3d GRID?
Appreciate your help in this regard
Old   October 8, 2008, 04:36
Default Re: Create 3d Grid query - Star cd 3.24.0 version
Andrea
Hi
I think you should do the tutorials in the Pro-AM section of Star-Cd to understand more of what you are doing...
You can create a toroidal fluid mesh directly through the CREATE 3D GRIDS USING SIMPLE SHAPES tool as you said. Before doing it you must go to Tool -> Cell Tool and activate a cell type where the type of cell is set to "fluid". This means that future cells created will be fluid cells, 3d cells.
If you have a complex geometry or you want to use the shell-surface-mesh you created in pro-surf you can follow the mesh creation process in pro-AM: by that way you can "convert" a surface mesh (shell type) to a volume mesh (fluid cells type for simplicity)...
You can store a mesh using the command "dbase", try to look at it in the help section of the code.
Hope that helps, bye!
Andrea
Old   October 8, 2008, 10:26
Pankaj
Thank you very much. I figured out my mistake and things worked well for me from there on!
I created a mesh using Pro-am and later compress the previous mesh using Create 3d grid tool and then generated a toroidal mesh!
Thanks again.
Old   October 15, 2008, 09:36
Wei
Hi Pankaj,
I am working on the transient moving mesh problem as well using STAR-CD 4.
I am looking for the tutorial 13 internal combustion engine in STAR-CD 3.
If possible, can you please send me a copy of the tutorial with practising file.
Thank you.
Wei
anybody know about the new version of star-ccm+ fast eddie Siemens 1 July 7, 2008 08:50
fortran version for star v.4 matej Siemens 2 August 15, 2007 08:06
Simple grid check query Ken FLUENT 0 March 27, 2007 00:47
Whens the next version of star out? Joel Siemens 5 January 13, 2003 10:09
Parallel STAR version Michael Schmid Siemens 1 November 7, 2001 09:41
