[Sponsors] | |||||
#21 |
Hi Balduin,
Sounds make you confused. 1)You should simply take the v31 *.mdl file and read it into v406. (No error.) 2)After that you type the command "cptran all". (No error. No missing celss.) I therefore, 3)Save .mdl in v406 (STAR-CD v406 closed automatically. Error printed at the linux console is 'line 284:5124 floating point exception'.) The saving problem drives me to convert the file to be .cel and .vrt. |
#22 |
Rep Power: 3 ![]() |
hi
im new to CFD and as i experience convergence problems in my mesh (designed using solid works and prosurf and proamm and exported to pro star), i redesigned my mesh in star design and it get converged in star design and later i export it to pro star by enabling "start pro star gui". then i tried to change the properties of the material (temperature, viscosity and density as function of time etc..) and run the .mdl file again, but once post processed, i noticed the material properties havent been changed and it remains in initial valued i entered in star design. is it possible for us to change the parameters in pro star .mdl file which is originally generated in star design?. can i model conduction and radiation heat transfer after getting the .mdl file and changing the parameters in pro star user guide pannel? (i ddnt follow the standard procdure, star design -> .dbs in pro surf -> pro amm -> pro star ) |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Repair Wall Distance Error | asd | FLUENT | 1 | July 29, 2011 12:36 |
| repair surface | laura | CFX | 0 | December 29, 2008 05:07 |
| Surface Repair for Meshing | Andy R | Main CFD Forum | 13 | May 3, 2008 14:33 |
| how to repair geometry by another way | Priscila | CFX | 4 | August 2, 2007 11:43 |
| Cells repair | Julie Polyakh | CD-adapco | 1 | August 2, 2003 05:20 |
