Error 28 Transient data file is not connected
Old   November 18, 2008, 11:02
Default Error 28 Transient data file is not connected
wei
I am running the gas exchange process of an engine using STAR-CD v3.26. I am able to create the geometry file. When I try to write the problem file, the error message 'error 28 transient data file is not connected' is printed.
what the error message means?
Old   November 18, 2008, 11:07
Default Re: Error 28 Transient data file is not connected
mohan
please connect the transient file and write the problem file You can type the following commands in output window
trfi,connect
geom
Old   November 18, 2008, 11:20
wei
The output display is,
EVNT*>
trfi,connect
**ERROR - UNABLE TO READ FILE test.trns
IT MIGHT NOT BE A TRANSIENT HISTORY FILE - PLEASE CHECK
TRAN*>
Old   November 19, 2008, 08:55
mepgzzi
If you are using es-ice for the engine mesh, try: evfi conn
Mepgzzi
Old   November 19, 2008, 10:53
Pauli
The error message means your model file is configured for an advanced (i.e. multiple step) transient yet you have no transient file.
You can use the transient module to create the transient file. The transient module is through the pull down menus: Modules->Transient.
You can use the command "time,single" to switch back to a simple transient. This method does not require a transient file.
Old   November 19, 2008, 11:09
wei
Thank you again Pauli.
When I make an empty transient file using module->transient, a problem file can be written.
In moving mesh case, what is the relation between the transient file and the event file? How do I create a proper transient file in this case?
Old   November 19, 2008, 12:32
Pauli
In version 3.26, you don't really need the transient module. Enter the command "time, single" & you should no longer need a transient file.
The event & transient files are not related.
Error while saving the case and data file Sri FLUENT 6 September 2, 2015 09:55
how to handel transient data with less file space steven CFX 2 October 27, 2006 17:01
transient data file in les computations eos Siemens 0 March 23, 2006 08:51
Transient Post Data file *.pstt Tony Siemens 3 October 27, 2005 07:28
how can I reduce the file size of transient data Yuan-Heng Huang Siemens 3 December 1, 2000 22:16
