VoF Interface definition
Old   January 7, 2009, 05:08
Default VoF Interface definition
Anto
Hi!
I'm trying, for the first time, to do a boat simulation in Starccm+. I don't know how to define the initial definition of the interface air/water. In the 2D tutorial there is an initial distribution as field function...
Thanks
Old   January 14, 2009, 02:11
Default Re: VoF Interface definition
ping
use the same technique - let's say up-down is in the Z dir with water surface at Z=0, then create a FF with air above z=0, water below. When you initialise you will see the water at the correct location if you have done it correctly.
The newish 6DOF feature can also be used with a flat wave - it has a parameter for water level - see the demo video below:
http://www.cd-adapco.com/media/demos.../DFBI_demo.swf
Old   January 19, 2009, 05:05
Anto
Thanks a lot! I'm using the 3.04 version, so I suppose that the 6DOF is on the 3.06. I will try it as soon as possible. All ok about the initial distribution of the free surface now, after few iterations, I've an overflow error: any suggestion? Perhaps I have to work on the iteration steps settings...
Streamline definition Jochen FLOW-3D 2 January 29, 2009 01:30
what is GGI definition in CFX? NITIN DEWANGAN CFX 1 August 7, 2008 22:48
Interface definition Alex CFX 2 September 12, 2007 05:18
b.c. definition john FLUENT 0 June 5, 2004 10:00
definition of u* for y+<10 Robert Spall FLUENT 0 May 29, 2003 11:40
