February 5, 2009, 06:25 |
fuel injection
Hey!!
I wanna simulate an injection of fuel(Dodecane(L)) into a high pressure cell. I wanna have a look to the length of the injected fuel jet and to the diameter and velocity of the fuel droplets. It's an Lagrangian Multi-Phase spray injection with atomization.The Atomization model is the "Huh-Model", the "MPI-2" is the nozzle model. Heat, Mass and Momentum Transfer are Standard with 0 for mass coef. and 1 for the slip factor. there is one inlet and one pressure boundary created. I wanna simulate pressures between 1e+05 and 100e+05Pa. That I can see how the pressure influences the length of my jet and the velocity and diameter of my parcels So, the problem is that the length of the jet is still constant. Doesn't matter if the pressure in the cell is initialized to 1e+5Pa or to 500e+5Pa. So, what's wrong with my simulation? I'm running the code of version 3.26. Maybe you've an idea;-) Thanks a lot. Johannes P.S. I'm a student from Germany, so sorry for my bad english ;-) |
February 5, 2009, 07:42 |
Re: fuel injection
Hi Johannes,
Are you using RANS or LES? Also, when you say length of your jet, do you mean the liquid jet, or the gas jet? Kian Mehravaran |
February 5, 2009, 08:08 |
Re: fuel injection
HEY Kian, i mean the length of the liquid jet (the length of the fuel jet). What's RANS or LES?
Thank you very much. Johannes |
February 5, 2009, 08:26 |
Re: fuel injection
RANS = Reynolds Averaged Navier Stokes equations, LES = Large Eddy Simulation, they are two ways of modeling turbulence...two radically different approach.
Try to look at the cfd wiki for more info For the injection problem, do you get the correct pressure (the pressure you want) in the injection chamber? Have you verified that? Regards |
February 5, 2009, 09:14 |
Re: fuel injection
hey!
ok, than i use RANS! I get definitely the right pressure in the chamber. try tp find sth. in the WIKI. thanks, Johannes |
February 5, 2009, 10:07 |
Re: fuel injection
Now the next question is how do you calculate the length of the liquid jet? By looking at the volume fraction? or do you look at the droplets directly? What is the temperature in the chamber? It could be that evaporation is very dominant in your case.
Kian Mehravaran |
February 19, 2009, 09:45 |
Re: fuel injection
Hello Johannes,
Although I am not familiar with star, my first guess is that you are doing an incompressible simualtion. In that case, the results do not depend on the actual level of the pressure, but just on the pressure gradient. If so, both initializations should lead to the same results. regards |
Display Modes | |
Fuel Injection Problems..... | Maria | Siemens | 1 | August 25, 2007 10:02 |
Fuel injection | Rams | FLUENT | 12 | June 20, 2006 02:25 |
Fuel Injection for Racing Car | Derry | CFX | 1 | January 30, 2006 22:38 |
injection of fuel into tank filled with fuel | mujahid | FLUENT | 1 | February 19, 2004 07:36 |
Fuel injection | Enrico | Siemens | 2 | December 23, 1999 04:37 |
