Batch Runs and Spread Sheets
Old   March 6, 2011, 13:47
Default Batch Runs and Spread Sheets
Scott
scottneh is on a distinguished road
I have been using STAR-CCM+ for about a year now and have been running multiple data sets and populating a spread sheet manually. I'm curious if anyone knows if there is a way I can create a batch file of sorts or a macro and use that to run my simulations. I'd like to be able to set the parameters from cells in the spread sheet and populate the spread sheet with data automatically. Or at least program the simulation parameters into the batch (macro) file and have it run and populate the spread sheet. The parameters that would change are, initial flow velocity, Mach number, and reference pressure.
Any help would be appreciated
Thanks
Scott
scottneh is offline   Reply With Quote
Old   March 7, 2011, 13:08
Ryne Whitehill
rwryne is on a distinguished road
You can set up a macro to export plots to CSV with ease. Just record yourself doing it in STAR-CCM+ and work it into a macro.
rwryne is offline   Reply With Quote
Old   March 7, 2011, 13:23
Scott
Thanks for replying. I'm have not created any macros yet in Star CCM+, I have only been running simulations manually so I don;t know how to build the macros yet. What I would like to do is take to data points from the last iteration and do that for each steady state run after it converges. I don't really need the plots that are generated during convergence.
Old   March 8, 2011, 15:57
Paul Hancock
Paulh is on a distinguished road
JAVA has the ability to interface with MicroSoft files through http://poi.apache.org/.
Paulh is offline   Reply With Quote
