Problem with Evload function in Star CD
Old   September 3, 2006, 11:18
Default Problem with Evload function in Star CD
Krithiga
While doing a tutorial in Star CD on transient flow in a mixer - sliding mesh (Tutorial 7.1), if a 'Evload' command is given, (commands given in the exact manner as specified in the tutorial) Star CD terminates and a message - "Segmentation Error" is displayed. Is there a way this can be avoided? Repeating the problem, the same error was encountered.
Old   September 6, 2006, 15:45
Default Re: Problem with Evload function in Star CD
Tom
in this case you need to contact support
Old   August 4, 2011, 06:23
abstrused00388@gmail.com
abstrused00388 is on a distinguished road
Segmentation fault is a memory operation error. even support cant help you. it will happen . bad luck
With Regards ,
SanZ
[I Will Have Plenty Of Doubts. So,
Send me Your Solutions Faster ! ]
abstrused00388 is offline   Reply With Quote
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 20:58
Field Function in Star-CCM+ mk_mat Siemens 0 June 24, 2008 16:51
field function in STAR-CCM+ stu Siemens 1 May 9, 2008 11:11
Stream function in Star-CD DenizeN Siemens 0 September 20, 2006 03:48
modifying the damping function(STAR CD) Ibrahim Siemens 2 August 15, 2005 10:01
