Streamling a Polaris "Slingshot" 3 wheel motorcycle |
May 12, 2015, 23:54 |
none
Rep Power: 11 |
Recently I bought a Polaris Slingshot 3 wheel motorcycle. (Information on this motorcycle is widely available on the Internet, so I won't bore you with a lot of words describing it, when a picture is worth a thousand words.)
The reason for my thread is to find out if anyone, or group, is interested in looking into designing a more streamlined body for it, (leaving the current stock tubular frame in tact), yet transforming the vehicle into one suitable for running at the Bonneville Salt Flats in the Streamliner motorcycle 3 wheel category. My problem is that I have no access to a "quality" incompressible CFD program. This is also a hobby project, meaning no outside sponsor. I have the skill and machines to make the body, and a fair knowledge of aerodynamics as applied to vehicles. What I don't have is the CFD software and knowledge to apply it to any resulting improved design. Hence the my question here, "Is anyone else interested in this project, and also has the means to run a design analyses of whatever design that comes about?" The motorcycle in stock form has a 2400 cc Ecotec 4 cylinder 175 hp engine. It is capable of 120 mph. However the stock body is made to produce a lot of down force and stick the vehicle to the road. (It'll pull your false teeth out of your mouth on its corning ability , of over a "G".) Yet the back half of the vehicle appears like the designer quit after designing the front half of the machine. Hence you can actually feel the drag that it produces. However,.......one Slingshot has already been equipped with a turbo charger running only 6 lbs. of boost. In a quarter mile it accelerated to 131 mph in just 11.3 sec. Cleaned up with a better body design, and running a turbo with the same boost, I have no reservations that the vehicle could top out, in otherwise stock form, at 160 mph +. Thanks for your time, and hopefully........your interest. cliff20 |
May 13, 2015, 07:50 |
Robert Strong
Rep Power: 11 |
Cliff,
Shoot me an email... robert.strong@strongsimulationconsulting.com I use ANSYS Fluent for all of my analysis. Thanks, Robert Strong |
May 20, 2015, 09:20 |
Michael Page
Rep Power: 17 |
Hi Cliff,
Maybe Simu-K can make you a sponsorship. You can contact me be e-mail for more information. Best regards, |
May 21, 2015, 03:43 |
hello.
I'm an aerodynamicist from Russia. Working primarily with open-source and free codes. Have a possibility to use HPC. Your challenge is quite interesting, but i'm not sure how serious your intentions. To be clear we're so far from each other to drink a couple of beer at friday. Need a contact, a dialog through FB, skype, linkedin or similar stuff.
practice makes perfect |
May 21, 2015, 07:30 |
Skeptic
none
Rep Power: 11 |
Skeptic:
I appreciate the reply. However I don't use Skype, or any of the others due to security issues. I would enjoy the beer, and the discussion, but as you mentioned, there is a distance issue. A shame, as I've seen some fantastic Russian work in aerodynamics. Especially on ramjet engines, and in ground effect aircraft and vehicles. Thanks again for the interest. That makes 4 of us out of 7 billion. At least I'm not alone ! Cliff20 |
May 28, 2015, 14:12 |
Simon
Rep Power: 11 |
Hi Cliff,
I'd happily take a look for you in OpenFOAM - I've got experience with external aero projects and this sounds quite niche and interesting. Drop me an email at info@momentum-analysis.co.uk if you like to talk more, or feel free to drop me some CAD and I'll get back to you with some thoughts and timescales. Regards, Simon. |
Simulation of rotating undershot water wheel | Miss Anna | CFX | 25 | June 7, 2016 23:24 |
static pressure in water wheel and open ambient | Ema40 | FLUENT | 0 | November 13, 2014 02:57 |
rotation velocity of a water wheel and rotating domain | Ema40 | FLUENT | 0 | November 12, 2014 10:50 |
