July 8, 2016, 18:08 |
Response of erythrocytes using 2-way FSI
NY
Rep Power: 10 |
Hi ,
I am working on a 2-way Fluid structure interaction project related to RBC in capillaries. I have designed a micro-scale shell RBC and a fluid medium which has diameter just above the dia of RBC. In the transient structural analysis I have defined two fluid surface interfaces: 1. Exterior portion of RBC(blood interacting with exterior) 2. Interior portion of RBC.(cytoplasm reacting with interior) In the Fluent medium I have defined the walls, boundaries of capillary tube and cytoplasm (hollow portion of RBC) which are supposed to interact with with the solid RBC in Transient. I have assumed that blood runs at x velocity and cytoplasm relatively at 0.97x velocity. Similarly, in transient I have 0.97x velocity, 9.7x displacement to Solid RBC When I run the analysis by coupling both systems I receive error by doing so. But if I reduce the time step (0.0004) sec for 10 sub-steps ,velocity to 0.0000097x and displacement by 0.000097x solution runs smoothly. Irrespective of correctness of result, Could anyone tell me why is that if i decrease the velocity, displacement and time steps there is result and why if i consider real time scenario this does not work? Thanks Last edited by mxl9549; July 10, 2016 at 16:03. |
FSI: How to transfer static pressure from fluent to ANSYS | momo_sjx | FLUENT | 0 | October 9, 2012 13:37 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 04:14 |
fsi | sun | Siemens | 8 | January 19, 2009 23:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
Could you suggest some Useful FSI textbook? | BI CHANG | CFX | 0 | January 14, 2006 14:31 |
