May 16, 2012, 08:06 |
mass flow convergency
Domenico
Rep Power: 16 |
Dear All,
I'm simulating a coupled system intake +rotor. The flow physics is quite complex and in order to judge the convergency. I use to look to the residuals values which are of a maximum RMS of e+04. However, the mass flow presents small fluctuations at the rotor (o domain) outlet. Do you think is worth to investigate the system with an unsteady simulation? The order of magnitude of oscillations is about 5.39*e-4. Thank you for your attention Regards |
May 16, 2012, 09:16 |
problem description
Can you describe the problem in some detail. Like how many blades you are modelling, sector of intake, interface between intake and rotor, boundary conditions etc.
May 16, 2012, 09:33 |
Domenico
Rep Power: 16 |
Can I give to you those detailed you asked for in a private way please. I can give to you my email.
Regards Domy |
May 16, 2012, 11:15 |
Please sure. turboenginner@gmail.com or pm me
May 16, 2012, 18:51 |
Rep Power: 143 |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 21:11 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
mass flow | Wenbin Song | FLUENT | 0 | September 27, 2005 13:00 |
Determine mass flow rate along flow path | Atit Koonsrisuk | CFX | 2 | October 5, 2003 04:47 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
