June 4, 2012, 11:49 |
5th order wave simulation
Kan Wang
Rep Power: 13 |
Hi everyone
I am running a simulation for the Stokes 5th order wave. There are an amount of paramters should be set to determine the wave length, and the solution seems very complicated which should be soluted using a program or something... So anybody can give me any suggestion? Regards Kan |
June 4, 2012, 18:59 |
Rep Power: 143 |
You can put quite complex expressions into CEL. Providing it is an algebraic equation you should be able to do that.
Alternately, if you need more power than CEL can provide you can use fortran, probably as a Junction Box routine so you can code it in Fortran. |
June 5, 2012, 06:13 |
#3 | |
Kan Wang
Rep Power: 13 |
Actually I have put a series of expressions into CEL, in which the wavelength was obtained with some simplifications. I read some references, indicating that the wavelength should be obtained by solving two iterative equations. But can CFX solve these equations? Is there any sources or examples I can follow? Thank you very much Kan |
June 5, 2012, 19:26 |
Rep Power: 143 |
You cannot solve these equations in CEL. You will need fortran for this.
Wave Simulation | solimcfd | CFX | 48 | December 27, 2016 05:26 |
1st order vs 2nd order | ken | FLUENT | 8 | March 14, 2013 03:43 |
2nd order boundary conditions for 2nd order discretization? | quarkz | Main CFD Forum | 30 | December 26, 2011 07:12 |
simulation of the long and short wave radiation | slim | FLUENT | 0 | December 1, 2007 15:01 |
weno upwind 5th order 1 d code | Chi | Main CFD Forum | 1 | March 11, 2007 22:44 |
