August 14, 2012, 04:03 |
need clarification
Shashwat
Rep Power: 14 |
Dear friend
I am doing simple flow analysis . This is transient analysis. Input is a variable pressure ( average pressure is 12000 pa -all the time) outlet pressure should be 0 Pa. with this condition I would like to increase the flow rate .I don't know the initial condition. I did as follows 1.steady state analysis I set the average pressure at the inlet and average velocity at the outlet .I varied the out let velocity when i need more flow.I did n't change the inlet pressure all the time. 2. Transient analysis end of steady state configuration I did the transient analysis now I use transient pressure at the inlet and I put 0 Pa at the outlet. I want to know is this correct way of setting different flow rate when the pressure doesn't change at the inlet and outlet all the time. Thank you for your kind consideration and your advice. Regards Shashwat |
August 14, 2012, 07:58 |
Rep Power: 143 |
I do not understand your question.
Did you do a steady state simulation as an initial condition for a transient simulation? What are you trying to model with the transient simulation? What is the problem you are seeing? |
August 14, 2012, 08:20 |
flow analysis in a stenosed artery
#3 | |
Shashwat
Rep Power: 14 |
My question is I would like to do simulation for different flow rate keeping transient inlet pressure and outlet pressure constant For example : my flow rates are 50ml/min, 60ml/min, 100 ml/min etc But I have to maintain the inlet pressure ( transient) and outlet pressure 0 Pa constant all the time for the above flow rates. Thank you Regards Shashwat |
August 14, 2012, 08:34 |
Rep Power: 13 |
if you set the pressuredrop (inlet-outlet) in your fluid-domain you get a massflow as a result
if you set the massflow and outlet pressure(e.g. 0 Pa relative) you got the inlet pressure as a result how can you vary the massflow in your geometry without affecting the pressuredrop? (1st law of thermodynamics or in simple cases without any work(vent...) or heat flux bernoulli equation) |
mesh clarification | shaswat | CFX | 1 | January 26, 2012 06:06 |
clarification needed | kmgraju | CFX | 0 | May 6, 2011 04:24 |
Clarification in FDM in Cylidrical coordinates | manisankar | Main CFD Forum | 0 | December 23, 2010 02:07 |
Clarification required for total pressure increase | Mahendran | FLUENT | 0 | September 28, 2007 13:48 |
Re: Convergence to 0.001% - again! - Seeking Clarification | R.Sureshkumar | Main CFD Forum | 0 | April 2, 2000 08:30 |
