CFD Post: Location of maximum and minimum velocities! |
August 29, 2012, 07:53 |
Mr CFD
I'm using Ansys CFD post. To get the maximum and minimum v component of velocity I'm using: maxVal(velocity v)@Domain minVal(velocity v)@Domain This gives me the maximum and minimum values of the v component of velocity. But I also need the location of those values. Is there a way to do this? Thank you. |
August 29, 2012, 14:47 |
Felipe Gobbi
Try creating planes and ploting contours on them.
By the colours you should know where to expect them! Good luck. |
August 30, 2012, 14:46 |
Mr CFD
Thanks, but is there a way to give me a precise location?
I've found that the minimum velocity is nearest to node 9234. Is there a way to determine the coordinates of that node with respect to my geometry? Thanks |
August 31, 2012, 05:33 |
Hi
i would create a Point(e.g. xyz-method: click in the x-pos. field and then on that node ... ) where the node is (then you have your location) and probe(X)@Point 1, probe(Y)@Point 1 ... haven't found a more elegant and automatic way to do this yet (maybe with variables/expressions?) |
August 31, 2012, 05:52 |
DB
Define a point with variable Maximum/Minimum of the variable you are looking for. Then export co-ordinates of these points, by export option in file, or probe X, Y and Z co-ordinate of this point if fuction calculator
-D.B Last edited by D.B; August 31, 2012 at 06:13. |
August 31, 2012, 07:34 |
thx D.B
somehow i newer looked at the different methods to create a point ^^ |
August 31, 2012, 09:51 |
Mr CFD
Thank you D.B. Using your method of defining a point, and then probing the point I was able to find the maximum and minimum velocities, and their coordinates.
Thanks |
cfd post, location, maximum, minimum |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 15:18 |
Maximum and minimum Values | me.ouda | FLOW-3D | 3 | June 24, 2010 02:14 |
Custem field function: Aveage, minimum, maximum | SAM | FLUENT | 0 | August 16, 2004 05:15 |
