June 6, 2020, 15:25 |
cfx BC profile error
Zese
Rep Power: 12 |
Dear Friends
I want to use BC profile of mass flow at the inlet but it gives me the following error. The parameter 'Mass Flow Rate' in object '/FLOW:Flow Analysis 1/DOMAINomain 1/BOUNDARY:Boundary 1/BOUNDARY CONDITIONS/MASS AND MOMENTUM' is defined to be "Single Valued" but it depends on the following field valued variables: , x, y, z. do you know what I should do? |
June 6, 2020, 16:30 |
Gert-Jan
Rep Power: 27 |
Show us the output file. That will give the required info.
June 7, 2020, 07:37 |
Zese
Rep Power: 12 |
Dear Gert-Jan
the error is shown in my cfx pre file and the simulation doesnt run until it get fixed. I attached output file. Thanks in advance |
June 7, 2020, 15:45 |
Gert-Jan
Rep Power: 27 |
You cannot set a massflow as function of x,y,z. The mass flow must be a single value. Something like 1 [kg/s]. The software will adapt the local velocity (nad possible Density through Pressure) such that the massflow is achieved.
The best solution would be to set the velocity as function of x,y,z. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
