extract data along a line or turbo line
Old   September 19, 2012, 05:45
Default extract data along a line or turbo line
Mehdi Bahador
Mehdi534 is on a distinguished road
I need to write a script to extract data anlong a defined line in CFX post progrom, but don't know the command or specific expression for data extract in sampled points, anybody know about that?
Regards, Mehdi
Mehdi534 is offline   Reply With Quote
Old   September 19, 2012, 06:09
No need for a script. Make a line object with the sampling points you want. Then export the line object. And if you are looking for the session file command for an action the easiest way is to record a session file where you do the action in the GUI, then look at the session file.
Old   September 19, 2012, 06:55
Mehdi Bahador
Thanks. Yes it works but when we export the data by this way it is saved in a file, I need to to generate several turbo lines and then extract the pressure data along each line and put them in a vetor for later calculations, I need a command in my script to obtain pressure data in each sample point (on the turbo line) and then put it in a vector.
Old   September 19, 2012, 18:31
My previous post explained how to generate session files to get the commands.
You could also do a python (or perl or any language you like) script which reads the export file and reassembles the data any way you wish.
Old   May 31, 2020, 08:58
Terbulent is on a distinguished road
Hi, I have encountered exactly the same problem, could you share how to do it? Thank you.
Terbulent is offline   Reply With Quote
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
automatic extract data in post colins CFX 0 January 14, 2004 09:47
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
